Detailing Engine Compartment and Engine??
Old Oct 15, 2007 | 03:44 PM
r6allstar's Avatar
r6allstar
Default Detailing Engine Compartment and Engine??
Planning on doing a SERIOUS cleaning on the new beast so I had a couple Q's. What is the best method and products to use?
Old Oct 16, 2007 | 08:02 AM
Danase's Avatar
Danase
Default RE: Detailing Engine Compartment and Engine??
ORIGINAL: r6allstar
For the engine compartment I HIGHLY recommend P21S Total Auto Wash. It is very safe and effective on cleaning the engine. Once the engine is cleaned and dried spray it down with 303 Aerospace Protectant. You will be pleased with the outcome.
Old Oct 16, 2007 | 08:45 AM
Juztang's Avatar
Juztang
I just spray all purpose cleaner/degreaser on the engine and let it dwell for a few minutes, then I come back amd agitate it with a brush. The spray off lightly with a hose. In the past I use CD2 to dress the engine, now it is getting hard to find. I've been using my Silk Shine Dressing on the engine lately and it works great too. I just spray it on the engine while it is still wet. Then close the hood and let the vehicle run fora few minutes, turn it off and pop the hood and your engine will look new again!
Old Oct 16, 2007 | 10:31 AM
Danase's Avatar
Danase
You want to be careful to amke sur ethe cleaner/degreaser you are using isn't going to oxidize the metal or turn the rubber and plastic white. One thing I tell everyone is to stay away from Simple Green in the engine and wheels.
Old Oct 16, 2007 | 10:36 AM
Juztang's Avatar
Juztang
Yes Simple Green can be harsh. My APC/Degreaser is completely safe on engines, it won't hurt the metal, rubber, etc...
Old Oct 16, 2007 | 12:31 PM
Danase's Avatar
Danase
ORIGINAL: Juztang
Good deal!
Old Oct 16, 2007 | 12:40 PM
99 GT vert's Avatar
99 GT vert
so when you clean the engine area on a day a new edge gt wha do you do about the coil over plugs that go over the spark plugs how do you protect them from getting wet
Old Oct 16, 2007 | 08:48 PM
BleedinBlue's Avatar
BleedinBlue
All I did to protect the coil packs/alternator, etc. was stuff paper towels around them. Then I just used as little water as possible. It worked like a charm.
Old Oct 20, 2007 | 08:49 AM
BleedinBlue
R6 (If you are still watching the thread...), I just gave my engine bay a quick cleaning yesterday. I stuffed papertowels around the coil packs and alternator (May not even be necessary, I was just being safe) sprayed down some degreaser and brushed with toothbrush, rinsed with water, let it dry a bit and then used armor all on the plastics and rubbers.
Easy as pie:
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
tmdm
Sep 4, 2015 06:45 PM
