easy way to clean the thin AC vents
Old Mar 4, 2005 | 11:03 PM
Master's Avatar
Master
Default easy way to clean the thin AC vents
anyone have an easy way?
Old Mar 5, 2005 | 01:18 AM
ho85GT's Avatar
ho85GT
Default RE: easy way to clean the thin AC vents
u can use pipe cleaners ( the thin wire covered in fuzzy stuff) or a brush that is shaped like a cylinder and has all sorts of plastic bristles, u can usually find them near the fish tank sections at pet stores, used to clean some air pump tubes on tanks
Old Mar 5, 2005 | 01:49 AM
fatguy_poolshark's Avatar
fatguy_poolshark
Ummm try taking q-tips and use those to clean vents it takes time but works good use armor all or something of that nature on them
Old Mar 5, 2005 | 09:06 AM
03SilverGT's Avatar
03SilverGT
I just take mine out and run some water over them, you can let them air dry or use an air hose. They are real easy to get out.
Old Mar 5, 2005 | 01:15 PM
dc_mann8's Avatar
dc_mann8
i just dont clean them...man, your cars must be clean!
Old Mar 6, 2005 | 03:21 PM
brando5.0's Avatar
brando5.0
What I usually do with vents is spray whatever you use to clean the vinyl (Armoral, Meguires, ect.) right into the vents. Then, use an air hose, or can of compressed air and blow them out. That way, it gets into all the corners and places that a q-tip or pipe cleaner might miss.
Old Mar 6, 2005 | 06:17 PM
vfast's Avatar
vfast
I ♥ Acer
you can use large q-tips if your a net freak.....I use a painter sponge does a good job for a buck
Old Mar 7, 2005 | 05:22 PM
Autogeek's Avatar
Autogeek
Former Sponsor
I either use these cotton detailing sticks or this auto vent brush.
Old Mar 8, 2005 | 02:40 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
I worked at a car wash for 2 years. Spray Some type of solvent into the vent, and use high pressure air to spray solvent around...or use a solvent and a "green pad" (3M). Simple green workes nicely.
Old Mar 22, 2005 | 10:38 PM
local134GT's Avatar
local134GT
Armorall will just attract more dust, better off cleaning them with water or some other cleaner that dosen't leave a residue.
