Engine detailing
Old Feb 2, 2008 | 11:14 AM
Streetracer911's Avatar
Streetracer911
Default Engine detailing
Hey guys I was curious as to what products I could use to clean my engine? The metal parts are oxidized and I want to make it look good. What type of detergent do you use to wash it? Do you use a hose or power washer? After washing what do you polish it with? I have seen some people use WD-40 and it looks awesome. Please give me your opinions...
Thanks
Old Feb 2, 2008 | 01:51 PM
ALMOST STOCK's Avatar
ALMOST STOCK
Default RE: Engine detailing
This should help !
http://duggerracing.com/techtips/engdetail/index.shtml
Old Feb 2, 2008 | 03:01 PM
Streetracer911
ORIGINAL: ALMOST STOCK
This should help !
Awesome....Thanks a ton....I never thought of tire cleaner....awesome idea....thanks again pal
Take care
if anyone else has anything else to add please feel free too
Old Feb 4, 2008 | 11:52 AM
99 GT vert's Avatar
99 GT vert
you should try to stay away form the pressure washer it can do some damage if you get water in the wrong spot a hose would be safer since you have a little more control of the direction of the water
tire foam will work but it tends to attract dirt and dust you would be better of useing an engine detailer like CD2
Old Feb 4, 2008 | 10:17 PM
joshcolbert801's Avatar
joshcolbert801
the best thing i have found is the same cleaner that some of my buddies use on their street bikes.... its avaliable in wal mart i thinkit is called blackhawk.....
Old Feb 4, 2008 | 10:33 PM
Bullitt G.T.'s Avatar
Bullitt G.T.
Simple Green is good for degreasing, and then use a garden hose on very light pressure to clean it off. High pressure water and electrical/mechanical components don't mix. Tire polish and Mother's Back to Black should help shine up some of those dull looking areas too. If you have any battery acid on the connectors use baking soda and be sure not to get any of the acid on yourself or the paint.
Old Feb 5, 2008 | 01:46 AM
007Bullet's Avatar
007Bullet
I needed this !
Galactic
Apr 29, 2019 02:56 PM
Nick Oliver
Oct 17, 2018 04:22 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
