1985 Sunroof
Old Feb 11, 2008 | 12:40 PM
Pluto's Avatar
Pluto
Default 1985 Sunroof
I have an85 mustang LX, that I believe has the origianl sunroof, whch needs a new seal, on the glass. Inasmuch as I do not want to break or chip the glass, does anyone have experience at removing the metal ring that holds the seal in place? I would appreciate any guidance as to the replacement procedure. Thank you, Michael
Old Feb 19, 2008 | 01:54 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default RE: 1985 Sunroof
Pictures would be helpful. I would call a Ford dealer and ask for Parts. Have them look up and order the seal for you and then if you are skeptical take it to a place that specializes in sunroofs to either show you the trick or do it for you....could be cheaper than having to put in a whole new sunroof if you break it []
If the sunroof is small and a perfect rectangle in shape with rounded corners then it is aftermarket. The stock sunroofs were rather large and the front edge countoured with the top edge of the roof/windsheild line - so that may help you determine if its original or aftermarket.
jehiggin
Nov 30, 2004 01:16 AM
kkspeed
Aug 4, 2004 02:41 PM
speedball1969
Apr 30, 2004 02:21 AM
troynb
Jan 11, 2004 01:05 AM
