Turtlewax Color Cure
I bought some of this off ebay because they dont make it for my color anymore. I went to apply the wax stick (looks like lip stick) and the stuff is pretty brittle. It just breaks off into little pieces. It says it needs to be warm, but its like 50 degrees outside. Is the stuff too old and the wax stale/brittle? Or is it just not warm enough. Id appreciate any suggestions/comments if anyone here has used it before. Its for a little rock ding btw.
it really does need to be warm to use. it most likely wont break apart if you warm it up enough
do you have a picture of the scratch or chip? you might need to use a little touch up paint, followed be wet sanding and polishing for best results
That stuff generally needs to be applied when it is around 80 or so out. It only lasts for a few days. Really go with the touch up and wet sand, you will be much happier with the end result.
Im a little bit unclear when you say buffer do you mean like solution or a porter cable polisher? Im a bit new to this stuff. But I do not have any type of polishing tool. I have several electric drills if they would work with attached pads.
