Polishing question
Old Apr 8, 2008 | 09:36 AM
Dan04COBRA's Avatar
Dan04COBRA
Default Polishing question
How are you guys polishing the top of your doors and rear quarters around all the trim?
I have a bunch of really fine scratches in those areas that I can't seem to work out. If they were anywhere else on the car, 1 pass of Optimum Polishwould fix it.
So what are you monkeys doing to fix it? I can get the pad on there, but the painters tape tears up the edges of my pads and most of the time the PC just sits there and vibrates doing nothing if I even put the slighest bit of pressure on it. There is only around 2 inches of surface to work on...
Old Apr 8, 2008 | 09:52 AM
99 GT vert's Avatar
99 GT vert
Default RE: Polishing question
im wondering the same thing that has to be the worst spot on my car with the rear quater panels
that and were the convertable top meets the area around the windshield how to keep it off the convt. top
Old Apr 8, 2008 | 02:33 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
I would have to guess use your hands and A LOT of elbow grease. I can't seem to get my pads to stay on very good, so using the outer edge of the pad would be out of the question for me [&:]
Old Apr 8, 2008 | 02:49 PM
BigFloppy's Avatar
BigFloppy
4" pads works for me
Old Apr 8, 2008 | 06:57 PM
SVTBill's Avatar
SVTBill
dan
you're going to have to get a polish that is workable by hand, you can use your OD light polish, but you'll be there all day. i'd try some menzera SIP followed up by OD light polish. i dont have any first hand experience with the SIP, but i hear it's one of the better polishes to be used by hand. there's no easy way around it, it's going to take time
try doing under your door handles...same case [:@]
Old Apr 8, 2008 | 09:40 PM
skitso's Avatar
skitso
i do the whole car by hand and with a 4" pad
Old Apr 9, 2008 | 09:43 AM
Dan04COBRA's Avatar
Dan04COBRA
I don't have any OD light polish but I do have some Poor Boys SSR1 that I think you can use by hand. I don't have any pads I can use by hand though. I do have a white polishing pad that seperated from the backing though...maybe I could cut a block and use that?
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
folivier
Sep 26, 2015 02:28 PM
