keeping headlights looking new
So I'm at the point where my headlights seem to be beyond repair. I'm planning on buying some new smoked clear corner ones, but I wanted to know if there's some good way to keep them from fogging up. Is there more that I can do besides buying a higher quality one?
If thathaze and stuff is on the outside, use http://www.crystalviewchemicals.com/to remove it. It works amazingly well. Mine weren't as bad as yours, but it made mine look brand new...
umm i would go to walmart buy th 20 dollar kit
the one tha attaches to your drill
and try that
or.....
2000-4000 grit sandpaper dont add toothpaste till you are done with sanding
toothpaste and vynal protectant
and try that
or.....
once you clean them .... spray them with clear coat. either kit is probably better then buying all the stuff indivdually. i just use 1500 sandpaper(wet), HSB w/ 1500 grit coupound and wool pad. then paint sealant or clear coat.
