Help cant remove swirls
Old Apr 13, 2008 | 04:59 PM
99 GT vert's Avatar
99 GT vert
Default Help cant remove swirls
i am in the process of detailing my dads 2000 F350 truck and i cannotremove some of the swirls to save my life it seen as if they just get worse i so far have used optimum compound and poorboys world ssr 1 trying to see if they would come out and they wont what do i need to do
thanks
Evan
Old Apr 13, 2008 | 06:14 PM
Juztang's Avatar
Juztang
Default RE: Help cant remove swirls
Have you tried to slow down your passes and apply more pressure?
Old Apr 13, 2008 | 06:44 PM
99 GT vert's Avatar
99 GT vert
acctually when i would go slow it seemed to make it worse and i would do alot of passes
it seemed to get better the faster i would go and the more passes i would make
i also tried applying more pressure that helped a bit till i pushed to hard and it seemed that the pad was heating up alot and felt like the backing might come apart
but now i know that i need to get a yellow pad
Old Apr 13, 2008 | 06:48 PM
Juztang's Avatar
Juztang
Hmm....It is hard to see what is going on without me seeing it in person. You might need a more aggressive pad. Are you make sure you are using a toothbrush to keep the pad clean? When you are using more aggressive compounds they will gum the pad up a lot quicker and you will have to clean it more often. This can cause more swirls and they won't correct as well either. Some paints are harder to correct than others too, you could be working on the same year vehicle with the same color paint and everything and one might have a hard clearcoat than the other.
Some panels will take more passes than others too.
Old Apr 13, 2008 | 07:01 PM
99 GT vert's Avatar
99 GT vert
well paint isnt i the best condition and no i didnt use a tooth brush clean it out that may be why i always get pissed off when the pad gums up
on the flat surface i couls get the swirls out fine but i was having problems on the curves were the hood would drop down a bit and the dry part of my pad would hit the paint and create more marks in the paint
let me get some pics of the area i am talking about
Old Apr 13, 2008 | 07:19 PM
99 GT vert's Avatar
99 GT vert
my biggest problem is were the middle area drops down to the edges
Old Apr 13, 2008 | 10:56 PM
Dan04COBRA's Avatar
Dan04COBRA
I was doing something similar to my Cobra just last week.
The dry part of the pad would hit and make some ugly micromarring..
I didn't soak it, but I shot a couple sprays of quick detailer on the sides of the pad where it was hitting, it put an end to the problems I was having on my hood.
Old Apr 14, 2008 | 09:57 AM
99 GT vert's Avatar
99 GT vert
thats a great idea dan i didnt even think of doing that
Old Apr 14, 2008 | 10:53 AM
Juztang's Avatar
Juztang
You can also tape off those areas that that the end of the pad isn't touching them.
Old Apr 14, 2008 | 11:34 AM
Dan04COBRA's Avatar
Dan04COBRA
What kind of tape do you guys use? Blue painters tape will chunk up and make my pads come apart.
