Headlight Question???
Old Sep 26, 2008 | 10:30 PM
562cobra's Avatar
562cobra
Default Headlight Question???
See post #8
Old Sep 27, 2008 | 12:24 AM
FixFalcon's Avatar
FixFalcon
If I had a 99-04 Cobra, I'd throw these on it.
http://www.americanmuscle.com/sm99hewiclco.html
Old Sep 27, 2008 | 05:39 AM
562cobra's Avatar
562cobra
yes i know fixfalcon, but i am on a budget right now. i'm sure you know how that is.
Old Sep 27, 2008 | 06:35 AM
jmac72187's Avatar
jmac72187
corner carver
I think you could wet sand a buff your headlights. I have noe experience doing it but I have heard of people doing it.
Old Sep 27, 2008 | 04:57 PM
RagingCrank's Avatar
RagingCrank
Yeah I've got a friend that works in a body shop that is going to teach me how to do this, I'll post the results and the how to.
Old Sep 29, 2008 | 11:18 AM
buster's Avatar
buster
wet sanding them is not difficult. I did it on my 01 and they turned out ok. It was better than buying new ones. You start with about 1000 grit paper and go progessively finer. I forget the exact grit numbers but I used 3 types. Then finished them with Meguires Plastix compound or some sort of fine buffing compound. I wasn't real happy with the results, but its alot better than buying new ones. Good luck
Old Sep 29, 2008 | 11:56 AM
99 GT vert's Avatar
99 GT vert
i did it to mine but they were to far gone it worked good on the parts that were not really foggy
Old Sep 29, 2008 | 06:30 PM
562cobra's Avatar
562cobra
depending on the condition
1.i started off with 220 grit, then went on to 400 grit, next was 800. I did all of these without the water process.
2. i then went with 1000 grit, water sanding of course. Next i went with 1500grit (water sanding) The last one i was going to do was 2000 grit, but all the stores were out.
make sure you tape the black moulding on the head lights like so
this is how my headlights looked before
this is how they came out
i'm not finished just yet, as i need to go over them with 1500 one more time and then with the 2000 grit. for the finer sandpaper use water. i wiped water on the headlights and the sandpaper.
after above process is complete put some plastic polisher on em. i bought this one
then polish them with a polisher and add clear coat. i chose this one
then let the clear cure (drying time of at least 3 hours) and polish the clear also
all the parts were bought at an autozone. the sandpaper was the assorted one varied from 220, 400, 800, 1000. i bought the 1500 in body repair store.
i have yet to finish mine up, but i already like how they look. here's a light on picture
all i need to do is buy the 2000 grit to finish them up. i will update this as i finish up.
and a sander will definitely make you love life
Old Oct 1, 2008 | 09:58 PM
562cobra's Avatar
562cobra
bump for anyone who would like to do this.
Old Dec 1, 2008 | 03:26 PM
562cobra's Avatar
562cobra
