which grit sandpaper?
Old Oct 6, 2008 | 10:31 AM
thtanoyinguy's Avatar
thtanoyinguy
Default which grit sandpaper?
which grit sandpaper do i use so i can sand the car down to repaint it? it has alot of chips, a few dings and some rust. i have painted before but i used the wrong sandpaper last time and i had to fight with swirl marks. what do you recommend?
Old Oct 6, 2008 | 04:18 PM
StriderTacticaL's Avatar
StriderTacticaL
I'm not sure what kind of sandpaper you use but I am pretty sure if you are tryng to take off old paint for a repainting then you have to use a solvent
Old Oct 6, 2008 | 04:46 PM
SVTBill's Avatar
SVTBill
you use a solvent to remove the old paint.
if you're talking about wet sanding during the painting process then it depends on how much clear you have laid and what kind you're using. the numbers should be around 1500 and up
i prefer meg's unigrit
SterlingStunner
5.0L V8 Technical Discussions
Sep 4, 2015 06:28 AM
Cool92GT
Feb 14, 2007 12:53 AM
JT76
May 15, 2006 06:15 AM
badazz68stang
Mar 19, 2006 01:14 AM
Dan66
Jun 22, 2005 10:17 AM
