Paintjobs
Old May 23, 2005 | 03:22 PM
StangGT804's Avatar
StangGT804
I ♥ Acer
Default Paintjobs
How much is a good paintjob? Also i have heard of paintjobs with sooo much clearcoat on it that, even if u tried scratchin it, there would be no effect. Is this true??//
Old May 23, 2005 | 03:59 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Paintjobs
It all depends on how good the body is to start with, paint jobs are 99% prep work. Color choice will affect the cost as well (red is the most $$). I will go out on a limb and say that you are looking at least $2000 for a decent job more if it is a color change (door and trunk jambs add up). As for clear coats you want no more than two med-heavy coats, more than that can cause yellowing due to the high solids in todays clears.
Old May 23, 2005 | 04:39 PM
Jimmz's Avatar
Jimmz
You can get a "good" paint job for around 3,000 but it can cost up to 5,000 if you get a color change and get a metallic flake with it to. So for a paint job that you would want to put on your stang your lookin at- grand easy...
Brian Emmer
Sep 9, 2015 02:50 PM
DutchPony
Jan 30, 2007 11:45 AM
uvastang
Chop Shop
Jan 16, 2007 02:50 AM
MEM 302 5.0L
Aug 30, 2006 12:02 AM
