Touch up paint
Old Mar 26, 2010 | 05:14 PM
roxmysox99's Avatar
roxmysox99
Default Touch up paint
While washing my car I noticed a few scratches on the front right corner of my bumper. The big one is probably 3 inches wide and a 3/4 of a centimeter tall at the tallest point. Would touch up paint bought from ford ofcourse fix this scratch? The scratch is noticibly black from a couple feet away. I'll post a picture later if necessary. The other couple scratches aren't as big. My car is white.
--Maleeh
Old Mar 26, 2010 | 11:10 PM
MelloYello's Avatar
MelloYello
Usually touch up paint looks worse than the actual scratch.. is it through the clear coat to base?
Old Mar 27, 2010 | 12:46 PM
roxmysox99's Avatar
roxmysox99
I believe so. Where the paint is gone, it is like completly black. Like the paint is completly gone.
Old Mar 27, 2010 | 03:28 PM
roxmysox99's Avatar
roxmysox99
Here are a few pictures:
Old Mar 27, 2010 | 03:44 PM
ryan1994mustang's Avatar
ryan1994mustang
if applied properly, the touch up paint would make it much less noticeable. its still not going to be perfect. it is also very easy to screw up a small touch up job and make it look worse than it started. whatever you do, dont use the little pen thing that comes on the touch up paint bottle. try and lay down multiple thin layers as opposed to one thick layer. im sure there are some touch up tutorials around here somewhere.
Old Mar 29, 2010 | 02:49 PM
budders's Avatar
budders
that looks buffable.. maybe not the top one, but the bottom ones do.
Old Mar 29, 2010 | 05:48 PM
bopiela's Avatar
bopiela
the top one would need touchup paint. and yeah, like ryan said, dont use the pen end. use the brush end. you may want to get the touch up clear coat as well, just as a little protection over that new paint. but take your time and look for a tutorial and you can get it done to make it much less noticeable.
also the bottom ones may be buffable... give it a shot with some rubbing and then polishing compound to see what happens.
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Oct 1, 2015 09:29 AM
Sep 30, 2015 12:39 PM
GLOCKer
Sep 28, 2015 07:36 AM
