Wet Sanding Help
Old Jul 14, 2012 | 08:44 AM
LordRipberger's Avatar
LordRipberger
Default Wet Sanding Help
Hey Guys,
I decided to try my hand in wet sanding and I have a few questions.
As luck would have it, I have a spare 2006 Mustang bumper and I am using it for practicing this.
I wet sanded the bumper with 2000 grit paper and then again with 3000 grit to smooth things out. I used poor boys SSR 1-4 and it looks great. The orange peal is down, however it is not gone.
My issues:
1) I cannot seem to get all the scratches to go away. I have buffed the area a few times and I can still see them in the light. However, when I run my fingernail over them, I don't feel anything nor do I see any paint missing. So this leads me to believe I didn't go to far down. Ideas?
2) I thought wet sanding was suppose to remove all orange peal. Since I can still see some, does that mean I didn't scrape off enough? And if so, I am already having issues with getting all the scratches out, wouldn't going deeper make more issues?
3) How bad is the surface suppose to look when you are done sanding? I saw the white stuff being washing off as I went through my strokes so I know I got into the clear. When I dried things, there was no shine and it looked like a white haze over the surface. Is that suppose to happen or am I looking for a much worse appearance when finished sanding?
Thanks guys.
Old Jul 17, 2012 | 10:18 AM
billy mack's Avatar
billy mack
hello, what I would suggest is to start with 1500 stay away from any lines, or edges, then go to 2000 and then if your a freak like me, 2500..
If i am doing a car i do a light 1200 first to get the high peel peaks removed..
the 3000 is over kill, and most polish will take out 2000 grit sratches.
importsmasher
Oct 9, 2015 04:42 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Sep 8, 2015 11:50 AM
SterlingStunner
5.0L V8 Technical Discussions
Sep 4, 2015 06:28 AM
NeoTokyo
Apr 11, 2004 12:57 PM
