poor mans exhaust
Old Jan 9, 2004 | 07:28 PM
iwrxit's Avatar
iwrxit
Default poor mans exhaust
put on a nice exhaust to keep the ridiculousness down. open headers sound nice but trust me, you will get tired of the constant bellowing.
Old Jan 9, 2004 | 07:40 PM
meowmixxer7's Avatar
meowmixxer7
but untill i can afford exhaust would cherry bombs work and not make me loose hp
Old Jan 9, 2004 | 07:42 PM
Sean's Avatar
Sean
You will not lose H.P., glass packs are straight through.
Old Jan 9, 2004 | 09:03 PM
DW-03GT's Avatar
DW-03GT
Geta set of cheap turbo mufflers, tehy sound a lot better than cherry bombs, parts america has them for like $20 and summit has some even cheaper. No you won't loose enough hp to make a difference.
Old Jan 9, 2004 | 09:51 PM
rockcrusher's Avatar
rockcrusher
DW-03GT has a good idea. As far as cherry bombs are concerned, their sound is a matter of taste. If you dig 'em, go for it. You won't lose a bunch of hp. Car Craft did a good comparo of the cheaper mufflers. Glasspacks outflowed every other muffler on a flowbench. CC ALSO dyno'ed them on a motor and the fell right in the middle. True, some of the old glasspacks weren't so hot, but they aren't around anymore. Cherry Bombs (the ones made today,anyway)and Thrush Magnum glasspacks are fine. Do want you like, and don't feel bad about it.
Old Jan 9, 2004 | 10:50 PM
jeep45238's Avatar
jeep45238
I ♥ Acer
Ultraflows actually have less backpressure than a straight pipe (1" of water less to be precise)
Old Jan 9, 2004 | 11:02 PM
Jugador1's Avatar
Jugador1
I ♥ Acer
yeah i saw that little article...isnt it weird...i wonder how the hell that is, but its true, it flows better
Old Jan 10, 2004 | 05:23 PM
DW-03GT's Avatar
DW-03GT
Back in the day glass packs flowed like crap even thou they were straigt thru, somthing to do with the internal baffling, don't knwo if they are anybetter now. They used to sound farty too, not like todays fart cans which sound like a 90lb chic farting, they were farty like a big fat guy the moring after pounding down a case of Genny cream ale (beer made in rochester, know for it's gaseous qualities)and eating burritos.</P>
I remember the thrush's pack blowing apart at the seams too<IMG src=smileys/smiley5.gif border="0">, talk about sounding like ***</P><edited><editID>DW-03GT</editID><editDate>37996.6462384259</editDate></edited>
Old Jan 10, 2004 | 11:58 PM
rockcrusher
Here's the full scoop on the old glasspack story. Old 'packs had louvered cores and were designed to be installed with the louvers facing into the exhaust stream. They were supposed to direct the sound into the packing material surrounding the core. Although you could see right through it, the louvers themselves created terrible turbulence and thus backpressure. Some cores were punched full of holes instead of louvers. Again, the ragged hole perforations protruded into the exhaust stream and caused backpressure. Today's Thrushglasspacks use holes punched away from the exhaust stream and into the fiberglass packing material, resulting in far better flow numbers.
Old Jan 11, 2004 | 02:18 AM
BLKSTANG9879's Avatar
BLKSTANG9879
thats has to just sound horrible. Open headers. Come on know. Your neighbors must wanna kill you.</P>
