20102 BOSS 302S
From what we can tell, the Boss 302 “S” is a purpose-built race car designed for use outside of the Grand Am series – the Boss 302R was built to compete in the 2010 Grand Am series. The Boss 302S though is built to compete in other series, and includes a bevy of enhancements to the car. It shares the same Boss R engine as the 302R, as well as an upgraded fuel and cooling system. It will use 3:73 gears, a torsion differential, and coil-over struts with extended ball joint lower control arms.
Like the Boss 302R, it gets a six-point FIA-spec rollcage, a lightened wiring harness, a rear-adjustable carbon fiber wing, a fiberglass hood with air extractors, Brembo brakes with huge rotors and so much more. The whole list of enhancements is below for the 302S, and the list is, well, huge. The cost is going to be $79,900 for this race-ready Mustang, though we’ll have to wait for official word from Ford to find out exactly what races the 302S is destined for.
Specifications:
Engine
5.0L BossR engine
Engine oil cooler
FR serialized intake badge
Boss 302 fuel system
Upgraded cooling system
Driveline
5L Boss 6 speed transmission with stock Boss 302 clutch/flywheel
Torsen Diff
3.73 gears
FR1 Muffler
Chassis
Front: coil over struts
Front lower control arms with extended ball joint and delrin bushing kit
FR adjustable front swaybar
Caster/Camber plates
Rear: coil over shocksTubular lower control arms with spherical bearings
FR Swaybar
EPAS with unique Ford Racing calibration
FIA Spec 6 point roll cage
Electrical
Lightened FR wiring harness
AMB Transponder
Switch plate – Start/ignition, aux switches
Interior
AIM data aquisition system with GPS
Recaro HANS Pro Racer seat
Fire system with 2 nozzles
Quick release racing steering wheel
Window net
Safety system triangle nets
6 point racing harness
Master cut off switch
Exterior
FR front splitter
Rear adjustable CF wing
Unique fiberglass hood with air extractors
Hood pins
18X9.5″ wheels
Boss 302S graphics package
F/R tow hooks
BrakesBrembo race 4 piston front brake system
2 piece 14″ front rotors
2 piece 12″ rear rotors
PFC racing pads
Brake duct kit
Stainless steel brake lines
FR brake booster assembly
Unique FR ABS calibration
Specifications:
Engine
5.0L BossR engine
Engine oil cooler
Driveline
Torsen Diff
3.73 gears
FR1 Muffler
Chassis
FR Swaybar
Electrical
AMB Transponder
Interior
Window net
Exterior
FR front splitter
Hood pins
18X9.5″ wheels
F/R tow hooks
PFC racing pads
Brake duct kit
bradleyb
Nov 27, 2015 07:50 PM
