Tune up info for a 66 200 cu.in.
Old Jun 23, 2006 | 11:45 PM
tms's Avatar
tms
Default Tune up info for a 66 200 cu.in.
Hi need tune up info for a 6 cyclinder 200 cu.in. and how to set the distributor ?
Trying the get it started and dose the engine to dash fround need to be hooked up ? before trying to start?
Old Jun 23, 2006 | 11:54 PM
Scott H.'s Avatar
Scott H.
Default RE: Turn up info for a 66 200 cu.in.
Yes it does. And make sure both ends of the cable are touching clean unpainted metal. Also make sure your ground cable from the battery is clean and is connected to an unpainted part of the engine block.
I get the feeling you have more issues than this though.
Does it not turn over?
Does it turn over but not start?
What is the whole story behind your question?
Old Jun 24, 2006 | 12:26 AM
tms's Avatar
tms
Yea there is a not connected wire i eye is broken off I'm going to replace it , the cables to the starter was rusty took off then sanded them off o think i'll replace to + side cable.
The starter on the finder well went chicking the starter clicked once the - post cable is in the engine mount bolt to the block it was cleaned to. if i can get it to tune over i sure to crank.
What is the gap on the points for the 200 cu. in. do you know ?
Old Jun 24, 2006 | 12:39 AM
Scott H.'s Avatar
Scott H.
0.019"-0.021" will get you close enough to run, but to really tweek it, use a dwell meter, and set between 39 and 40 degrees.
The ground strap between the engine and the body will not keep it from cranking. You are on the right track to replace those old cables though. Also, I'd suggest making sure the engine will turn over by hand. Just to make sure it's not mechanically locked up.
Good luck,
Scott
Old Jun 25, 2006 | 12:43 AM
tms's Avatar
tms
Well I know the batttry was week and used jumper cables to jump I might need a fully charge battry.
I had a dwell light until mice chuwed the cables all to pices oh well try next week!
got to go to work tomarrow had to work on my truck!
Old Jun 25, 2006 | 12:52 AM
Soaring's Avatar
Soaring
I ♥ Acer
We need spell check on this forum. I'll see what I can do.
Old Jun 25, 2006 | 12:59 AM
67t5ponycoupe's Avatar
67t5ponycoupe
I agree. I need it myself sometimes. I find myself cutting and pasting into word if I think it is that bad. BTW Dwell is not set with a light it is set with a meter. When you adjust dwell you are adjusting point gap. If you are using a light you are adjusting the timing.
carid
Jul 8, 2016 09:55 AM
firecoyote
Sep 27, 2015 02:37 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
Sminemann
Sep 17, 2015 09:24 AM
whatsup62
Sep 3, 2015 01:38 PM
