My Hurst Pro shifter is in!
i think it looks very good and smooth, prefessionally done looking. Id prefer a white shifter ball personally but thats beside the point since its your car and not mine. good looking work though.
how hard is that to do? i have a B&M one on my C4 but i didnt put it in, the previous owner did....eventually i wanna take it for a T5 swap....
It was not that bad, I have done harder installs. I have not done the other cable end on the tranny yet. I went with the wood ball cause my steering wheel is wood as well.
+1 on the white shifter ball...I know you got wood trim in the interior but the wood ball makes it feel less restomod-ish. j.m.o.
Other than that it looks sweet though, I like that you color matched the lower bezel to the car....nice touch!
Shifty....i know when i put my b&m pro stick in it was super simple because most aftermarket ratchet and gate shifters are all cable driven, so its just a matter of hooking up the linkage and then running it through the gears to make sure the cable adjustment is setting the right shift points. Whats nice about the cable is that you can mount the shifter back a lil bit futher---more comfy.
ORIGINAL: slickman
Correction, PRN321.. Get it right dude!
ORIGINAL: Soaring
Looks good for a PRNDL. You woosy. I would have thought you would put a T5 behind that bad engine.
junior04
Sep 28, 2015 10:53 AM
