Question..... How far do you go?
This is probably a dumb question to ask in this group.
I have a 69 MACH. Had it since late 70. Asked about paint earlier. The 351W is on a stand.
It needs a new water pump. Air Cleaner has a dent in it and one valve cover has a dent. (motor mount let loose years ago) I am going to replace all these or fix them.
But, then I look at "chrome".
I kind of want this to be stock. But then, a little Chrome wouldn't be all bad under the hood would it?
What should I do now and what later?
Have a Paddock catalog laying here. The "351 valve covers" look kind of good. The chrome water pump looks good.
This is worse than buying a new car.
Appreciate the input,
Tom
Tom
Well, a lot of us go further with the engine bay than with the exterior. I know several of the forum members who have extraordinary engine bays. Take a look at the gallery for some examples:
clutch's
Uwt's
and mine:
(im fairly proud of it, and it occupies much of my time)
In other words, the possibilities are only as endless as your wallet.
clutch's
Uwt's
and mine:
I would steer clear of chrome. Get some cool ALUMINUM "powered by Ford" V/C's, and get an aluminum water pump too. Less work, and you can clear coat them to save that look. Just make sure it's Hi-temp stuff, if you can't get it at a parts store, try Eastwood's, they have some really cool stuff. Luck
That's why you don't see a lot of chrome valve covers or oil pans in racing. On top of that it is just a stamped steel cover so it will leak like a stock cover as well.
Aluminum is much better, even if it's polished. And the sealing surface is much better, so your engine stays cleaner, longer.
ORIGINAL: 68COOP
I did some digging, and found some thru Eastwood. It's called "Diamond Clear" and it withstands heats up to 300*F. I don't think they get that hot, do they??? It's for bare metal, and they have some for painted surfaces that go to 250*F too. It/they go for 11 bucks a can, and they cover 6 sq ft per can. Again, I don't want to step on any sponsers, so if anyone knows where this Man can get it, please respond. Eastwood's # is 1-800-345-1178, give them a call and see what they say. I would check the local parts houses/hardware stores first. Hope it helps.
ORIGINAL: 68COOP
Good point about shopping our sponsers first! I always do try to do that. I figure they help make this great forum possible. I also think that if they gave sub-standard service, they wouldn't remain a sponser.
