Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
What to get next?
Old Mar 1, 2007 | 12:39 PM
njmpanther16's Avatar
njmpanther16
Default What to get next?
I have a 03 V6 Mustang with a cat-back exhaust system, and I was looking at what I was going to get as my next upgrades. I was looking into a posi unit because I want both wheels to spin but would gears be more beneficial? I don't know what gears come stock in this car but I was looking at some 3.73's, I just don't know if they will work real well without having posi in the rear, I got about $400 to spend including the install, I have a friend that can install anything without really tight tolerances, like gears, but he has never installed a posi before.
Does anyone have any other suggestions for things I should get?
Thanks!
Old Mar 1, 2007 | 07:56 PM
924banger's Avatar
924banger
Default RE: What to get next?
Have you done the basics? Like CIA, bigger throttle body, programmer or just a chip, underdrive pullies, little things like that? If it's a manual, better clutch, shifter. For auto, maybe a power upgrade.
I don't know much about rear ends, but I thought you should have a certain amount of power before a posi is needed? Unless you just want one. For 400 you could buy alot of small power boosters and install yourself. Maybe that will give you some ideas.
Old Mar 2, 2007 | 12:44 PM
njmpanther16
I put in a Pro 5.0 shifter and i was thinking about putting in some underdrive pullies. I was talking to a guy who does work on my budies 350 z and he said that it not necarssay to get a bigger throtal body now. he said that i should get more power adders before i do that. and do think it is worth it to get a CAI? i have talked to oter people woh said that the posi would be a good investment but i am just trying to get different opinions.
Thanks.
Old Mar 2, 2007 | 10:11 PM
924banger's Avatar
924banger
Yes get a cold air intake. They give you better throttle response and up to like 10-12hp on some vehicles(don't know which ones). They don't make them for my car so I can't buy one....I will have to make one. If you don't want to buy one then drill holes all over the bottom of the stock intake box, you will still see a gain.
Old Mar 4, 2007 | 12:40 AM
njmpanther16
Ok i will def d that next.
Thanks for the help.
