BUSTED DRIVE PULLY STUDS
PREVIOUS OWNER (re-builder)BUSTED OFF 2 of 3 BOLTS HOLDING PULLY ASSY TO THE DAMPER. FOUND OUT THE HARD WAY !clank-clank-clankety-clank!!)
GOT THE PULLEY OFF, BUT CAN'T GET THE DAMPER BOLT BUSTED LOOSE!
IS THERE A TRICK ON JAMMING THE CRANK SO IT WON'T TURN WHILE I MUSCLE THE BREAKER BAR ??
THX MUCH!
THX MUCH!
Hi Skip and John, welcome to Mustang Forums!
Have you tried using an impact wrench? You will probably get more responses it you post your question in a tech section instead of the Forum Issues and Feedback section. Sorry I couldn't help more.
Good luck!
Good luck!
dalefrancis88
Sep 11, 2015 07:15 AM
Sep 8, 2015 11:50 AM
