Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
Stupid check engine light!!
Old Apr 30, 2019 | 10:18 PM
Peschdugga's Avatar
Peschdugga
Default Stupid check engine light!!
I've got a 2014 Roush charged stang with a code p219a that states it is fuel/ air ratio issues but it keeps throwing my check engine light! Any help on this issue will be much appreciated.
Old May 1, 2019 | 02:40 PM
08'MustangDude's Avatar
08'MustangDude
Banned
BANK 1 A:F Ratio, not both banks. It means that one or more cylinders in bank 1
are off. The air fuel imbalance monitor is designed to detect differences in the air fuel
ratio between cylinders per engine bank.
Possible causes:
Leaking or contaminated fuel injectors
Low fuel pressure or running out of fuel
Leaking evaporative emission (EVAP) canister purge valve
Exhaust or intake air system leaks
Exhaust gas recirculation (EGR) system
Positive crankcase ventilation (PCV) system is leaking or the valve is stuck open
Ignition system
Incorrectly seated engine oil dipstick, tube or oil fill cap
Yes, it will keep illuminating the CEL. Any emissions related failures will light the CEL,
that is required by Federal law.
Old May 1, 2019 | 05:20 PM
Peschdugga's Avatar
Peschdugga
Default Don't know
Thank you for the reply... my car only has 21000 miles on it so I'm just worried why the MAJOR issues related to this code. The car is basically brand new!!
Old May 1, 2019 | 08:06 PM
JimC's Avatar
Super Moderator
Unless somehow the forum function is causing your issues, you are in the wrong section.
This is for:
You ask questions about your car in the section for your car.
Old May 1, 2019 | 08:50 PM
Peschdugga's Avatar
Peschdugga
Default Sorry Jim
I'm new to this forum so can a guy get a pass? Sorry to post something in "wrong section". Besides my man answered my question even though it was not the "proper" whatever. Stay happy bud.
