Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
White smoke
Old Feb 12, 2021 | 05:32 PM
Recorded's Avatar
Recorded
Default White smoke
I'm not sure if this is a huge issue or I'm just overthinking it. But whenever I turn my car on, there is no white smoke coming out of the exhaust only on one side. Still, when the temperature gauge starts moving, I get white smoke but then once it gets to a certain threshold, it stops, and I don't have overheating issues, and my car doesn't misfire unless I put it under enough strain, I.e., letting the clutch out too quick. The Head gasket was changed in August of this year. I might need to retorque the heads, but I want professional input before deciding to do that because that would require taking the header off and because of how tight a spot it is, I would prefer not to. And if it's not the problem could it be a vaccine leak because there is also a p0171 code (system lean bank one).
PoppaAsh
Jun 17, 2007 11:52 AM
