Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
Electrical issue
Old Sep 29, 2022 | 03:25 PM
Nighthawkthe4.6's Avatar
Nighthawkthe4.6
Default Electrical issue
Okay so I replaced my headlights with my buddies because his were more clear and his bulbs were brighter not 100% sure what kind of bulbs but nothing crazy. Later on that day (tested to see if they worked and that was about it) I was headed out to ride and when I turned it on and my left signal light was stuck on. I tried to play with it a little my right side worked normally then it just turned off about 3-4 minutes later my dashboard went dark. And about 5 minutes after that the car died on me, fuel pump wasn’t priming thought the fuel pump went out on me. Got it replaced still had the same problem they said it wasn’t getting Power to it so they changed the module and it did nothing, said that it wasn’t getting a ground to the so they created one with a switch. Now the car runs but runs very rough once warmed up and is has a P1235 code
Old Sep 29, 2022 | 03:26 PM
Nighthawkthe4.6
ANY ADVICE HELPS!!
Old Sep 29, 2022 | 06:55 PM
JimC's Avatar
Super Moderator
Unless somehow the forum is causing your problem:
This section won't get you much result. There is a section for every generation and that is where you need to post your question.
89530stang
Mar 3, 2008 10:13 PM
