Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
P0720 code coming back after replacing
Old Aug 13, 2023 | 08:02 PM
Brayden34's Avatar
Brayden34
Default P0720 code coming back after replacing
So I have a 2006 mustang 4.0 v6 automatic, getting code p0720( output speed sensor ) I replaced it and it comes back . O/D light flash and speedometer don’t work . I tested resistance to all the sensors on the transmission (input , turbine Output speed sensor) all was good also checked harness not damaged has power and ground . I’m lost on what to do , could it be the TCM, the 6r80 transmission had the same issue and it’s the TCM lead frame which the 5r55s transmission doesn’t have (2005-2009) transmissions. Seems to be a common problem with the 2005-2009 mustangs have anyone had this issue?
Old Aug 15, 2023 | 07:39 PM
JimC's Avatar
Super Moderator
Welcome to the forum, please take the time to learn how things are arranged. Every generation has a section. This question for example belongs in the S197 section
Unless somehow using the forum is causing your issue:
