Help ign switch does not have hot all time 5.0 swap
I have a fuel injected 5.0 installed computer needs power on every ignition switch except on off position. 66 original switch is not design with a 4th wire that will be power hot on every switch position except off.
how would you wire ignition switch when switch is on than wire is hot it is not hot in start position. I need a wire power hot for my car computer the moment switch is turned on and also when ignition switch is on start position.
switch has accessory wire, starter wire, and power wire, dont have any power in the other wire in any switch position.
Not sure why you posted in this section for your question:
unless somehow using the forums is causing your issue.
Might be better in the motor swap section?
Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
