Short Shifter Handle
Old Feb 14, 2004 | 06:30 PM
Krusher's Avatar
Krusher
Default Short Shifter Handle
if I keep the stock shifter but change the handle... what does that do? Will it shorten the throw? I'm assuming yes but I wanted confirmation.
Old Feb 14, 2004 | 06:54 PM
BCisme's Avatar
BCisme
are you talking about the shift ****?<IMG src=smileys/smiley5.gif border="0">cuz a shifter aint much more than a **** and stick.
Old Feb 14, 2004 | 07:00 PM
Krusher's Avatar
Krusher
</P>
no.... not the ****. There is a lower handle and an upper... I want to replace the upper with a shorter one... I guess I'll just get it and find out how I like it.</P>
Old Feb 14, 2004 | 07:01 PM
BCisme's Avatar
BCisme
oh i see. well it'll shorten the handle, but no the throws, as the bottom part is what's actually doing the gear changing. your best bet is a steeda tri ax or a pro 5.0, you can find one cheap on ebay. <IMG src=smileys/smiley16.gif border="0">
Old Feb 14, 2004 | 08:13 PM
vfast's Avatar
vfast
I ♥ Acer
short handle just will make it harder to shift to 3rd
Old Feb 14, 2004 | 08:34 PM
mkspeed26's Avatar
mkspeed26
</P>
and make the **** lower.get a real short throw shifter
</P>
Old Feb 17, 2004 | 12:46 AM
CobraSVT33's Avatar
CobraSVT33
Default RE: Short Shifter Handle
i have the short handle for the shifter got it from kona racing, doesn't short the throws just the height of the handle your better off gettin a short shifter steeda tri-ax is best but if you wanna save some cash upr makes a replica which is guranteed for life and less money
www.uprproducts.com
Old Feb 17, 2004 | 03:51 AM
hotrodman's Avatar
hotrodman
I ♥ Acer
i got a pro 50 shifter ,,the short handle sucks big time you cant get enough levage on it ,,i use the stock long handle on it...a also have a tri/axe dont get it,,and i dont like it,,should have got another pro 50..
Old Feb 18, 2004 | 02:55 PM
mkspeed26's Avatar
mkspeed26
B&M sells good ones too, i like the pro ripper shifter
Old Feb 19, 2004 | 09:51 PM
Buzzstang's Avatar
Buzzstang
got with the pro 5.0 shifter base and the hurst indy handle it is just right for me. those short handles on the pro 5.0 shifter are good for busting the radio on a hard shift to 3rd.
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
