Redline...
Old Mar 6, 2006 | 12:39 AM
97BlackStang's Avatar
97BlackStang
Default Redline...
Simple, What determines a redline in an engine? I know it has something to do with the components, but i mean were do u know when to stop increasing it?
Old Mar 6, 2006 | 12:55 AM
alexr's Avatar
alexr
Default RE: Redline...
the factory probably destroys plenty of engines determining that.
Old Mar 6, 2006 | 01:15 AM
97BlackStang
Hmmm. Then what about engines that are built custom?
Old Mar 6, 2006 | 02:19 AM
alexr's Avatar
alexr
its a simple equation. you take the engine displacement, multiply it by the diameter of (1) cylinder, all over (divide everything) the recipricol of Pi. that should give you an estimated max speed, take that number and multiply it by your gear ratio (3.73, 4.10, etc) and subtract 500rpms and that should give you a close estimate for the redline rpm.
Old Mar 6, 2006 | 02:20 AM
alexr's Avatar
alexr
by the way, that isnt true.
Old Mar 6, 2006 | 02:41 AM
ShadowDrake's Avatar
ShadowDrake
Double posts are for losers
Check with the manufacturer of your engine's internals, they probably have a rating. Keep in mind also your valve springs, if you spin the engine too fast the valves will float, and you'll run into a natural rev limiter. We have interference engines too, so floating valves could mean major trouble.
As RPM's increase, the load on the moving parts becomes much higher, it's not proportionate. There's a way to figure it out using math and knowing the most force the piston, rod, and crank can take... but that's where the money is . Get a cam that makes the most power around 5000 RPM and limit yourself at 6000-6500 RPM. Sure you can make more power up higher, but you run into diminishing returns.
Old Mar 6, 2006 | 06:01 PM
97BlackStang
Im not building an engine or anything, i was just wondering how you dertermine that, cuase you cant just say OH about 9000K sounds good...lol
Old Mar 6, 2006 | 09:02 PM
alexr's Avatar
alexr
they pick numbers out of a hat
Old Mar 6, 2006 | 10:56 PM
97BlackStang
You never know
Old Mar 6, 2006 | 11:09 PM
alexr's Avatar
alexr
they do, you dont believe me?
