So I got a Quote for gears.....
Old Feb 23, 2004 | 01:04 AM
95_GT_Stang's Avatar
95_GT_Stang
Default So I got a Quote for gears.....
So i got a quote for my gears, goin with the 3.73's. Now the guy said for everything it would be $450 out the door. This seems a lil high for me. Would I be better off buying the gears and an install kit through summit and then taking them to a shop to do them, or is this quote good enough? I normally do all the work myself, but rear gears are not something i want to be messing with.
Old Feb 23, 2004 | 01:09 AM
hotrodman's Avatar
hotrodman
I ♥ Acer
Default RE: So I got a Quote for gears.....
i do myself ,,but you might want to get that done somewere if dont no how to do.. 450 dont sound that bad ,,
Old Feb 23, 2004 | 02:45 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
I got a buddy at a local dealership that will do mine for 150 if i buy the gears from him.
Met him at a car show he was in a 32 ford with a crate motor in it.Maybe check around at a few shows or ask friends who are into performance cars and building them up.450 seems high to me as well.
Old Feb 23, 2004 | 06:46 PM
vfast's Avatar
vfast
I ♥ Acer
450.00 is ok if he has the gears and is replacing bearings like axle bearing and seals,pinion bearing and seal,syth oil
Old Feb 23, 2004 | 09:30 PM
95Stealth302's Avatar
95Stealth302
I'd pay that much for a rear end rebuild like Vfast is talking along with the gears. Shop around a bit and call some Speedshops, but otherwise 450 is ok, so long as he's doing more than just putting in the gears.
Old Feb 23, 2004 | 10:04 PM
grabbem88's Avatar
grabbem88
hell,turboconnections wanted $750.00! now that is high,anyways find a friend that has put gears in.have him help you so you'll know what to do next time. its a win,win situation pay him a few bucks and you learned something.
Old Feb 24, 2004 | 07:42 AM
04ShakinSteed's Avatar
04ShakinSteed
I ♥ Acer
You figure the gears are $160 average price, so your talking about $290 to install. I think it is a little too much. On gears, I think $150-$200 is common for install.
Old Feb 24, 2004 | 03:21 PM
hotrodman's Avatar
hotrodman
I ♥ Acer
for exp,, 180.00 to set up.......80.00 brgs........gears 200.00........plus axle brgs ,seals 30.00.....limtined slip. lube 3 qts of gear lube...30.00...what does that come out too..more than 450.00,,,thats here in town..i do myself,,,,,
Old Feb 24, 2004 | 05:27 PM
vfast's Avatar
vfast
I ♥ Acer
dude..this guy can't ....alot of places will tell you a high number because they don't want your work and they think hell if he's willing to pay that much then they'll do it.. I have done this on home repair.....some times the best place is word of mouth..check with some friends who have had them done...
Old Feb 25, 2004 | 07:48 AM
TheGmKiller331
I ♥ Acer
If you are being offered all thats been mentioned above and not just straight putting gears in then you JUMP ON THAT RIGHT AWAY!Thats a hell of a deal.I meant for only gear install 450 wasa bit steep.But if all the bells and whistles are being thrown in go for it.
Post a pic of the smile that will be plastered across your face after you break them gears in and get on it for the first time.
