a/c system
Old Mar 18, 2006 | 12:39 PM
KillSwitchNY's Avatar
KillSwitchNY
Default a/c system
i have an 88 GT and some ******* before me cut some of the air conditioner lines on my car so i have no a/c.
what years did the a/c system stay the same for, and would i be able to use everything from a 4 cyl?
i figure i might as well find a parts car and hope it has working a/c that i can swap unless anyone knows where i can find complete systems minus the compressor
Old Mar 18, 2006 | 01:21 PM
Chopper's Avatar
Chopper
Default RE: a/c system
The parts should fit but I have no experience with you particular application.The trouble comes when you get everything put together.Anytime an A/C system is discharged and is allowed to sit exposed to the air,water and dirt get into the system and the lube gets out.This will kill the compressor quickly and clog the orifice tube and corrode everything else.I would strongly recommend that before you put anything together you talk to an A/C expert and see if the new/used parts can be cleaned outside the car.
Old Mar 18, 2006 | 03:29 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: Chopper
+1. If you were to bring it to me, as a certified A/C tech, I'd recommend replacing most of the remaining system. SOMETIMES, you can get away with flushing the system. But that depends on how long it's been open. Minimally, I'd recommend new hoses, as the older ones are not up to the higher pressures of R-134, a new orifice tube, new reciever/dryer, and a full flush of the system.
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
69Volunteer
Sep 30, 2015 10:39 AM
