lincoln mark7 Rear
Old Mar 22, 2006 | 02:52 AM
KillSwitchNY's Avatar
KillSwitchNY
Default lincoln mark7 Rear
some of you may know that ive asked about the friggin lsc rear quite a few times but i have a few more so i dont go buy a rear and find out later something wrong...
will an 89 lincoln mark vii rear bolt in my 88 gt
what model car do i need e-brake cables from? (i hear the stock fox cables are too short)
do all the lincolns have rear disc brakes?
and what gears did the rears come with?
and are the lincolns the same bolt pattern as the 94 - 04 5 lug mustangs
thanks for the help hopefully i can get some answers soon so i can pick up a 5 lug disc rear!!
Old Mar 22, 2006 | 06:26 PM
TBird232ci's Avatar
TBird232ci
Default RE: lincoln mark7 Rear
The rear bolts in.
Gears are either 3.08's or 3/27's.
Some are open rear, some are traction lock.
Yes its the same lug pattern as an SN95.
84-92 Lincoln's have disk brakes.
84-90 use the SVO/Mark VII style brakes, 91-92 use turbo coupe brakes.
The lincoln cables *should* work.
Keep in mind that the Lincoln rear will be over an inch wider per side than your stock mustang rear.
Also keep in mind that you will need the center rubber brake line from the lincoln, and may need an adapter to make it work.
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
