Steeda Tri-Ax Shifter
Old Mar 22, 2006 | 08:33 AM
Endostu's Avatar
Endostu
Default Steeda Tri-Ax Shifter
Hey just a quick question here.......i recently bought a Cobra which the previous owner installed a Steeda Tri-Ax shifter on. Sometimes when driving its hard to get it into the gear mainly when going into reverse. It doesnt grind or anything just hard to put it in gear. Anyone know what might be the cause of this or if there could be an adjustment to fix this problem? The car only has a little over 39,000 miles on it and has been serviced frequently. The clutch seems to be in perfect condition and i dont think its that. Thanks
Old Mar 22, 2006 | 12:08 PM
BraMas's Avatar
BraMas
Default RE: Steeda Tri-Ax Shifter
Mine does the same every once and a while. Just really hard to get in rev. Maybe once a week if even that often. Have you tried putting it in 3rd before you go into Reverse? It is supposed to realign everything to make it easier to get into Rev.
Old Mar 22, 2006 | 03:52 PM
Endostu's Avatar
Endostu
Yeah i found that out to....if i have trouble going into reverse then i usually go through another gear then try it again and it works. So basically theres no real way to fix that?
Old Mar 22, 2006 | 04:53 PM
ShadowDrake's Avatar
ShadowDrake
ORIGINAL: Endostu
No, it's just an issue with the transmission. It's "normal" but annoying either way.
Old Mar 22, 2006 | 05:32 PM
2VNA's Avatar
2VNA
^+1
Old Mar 22, 2006 | 05:43 PM
bdwjdw's Avatar
bdwjdw
It was done that way to keep you from accidentally putting it into reverse. Just put it in first then reverse
Old Mar 22, 2006 | 05:44 PM
kcp1989's Avatar
kcp1989
ive heard royal purple tranny fluid can minimize this
Old Mar 22, 2006 | 11:45 PM
Endostu's Avatar
Endostu
Ok well thanks a lot guys
firehorse02
Nov 16, 2015 11:28 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
Sep 24, 2015 09:18 PM
