Leaking Head Gasket? :[[[[
Old Mar 28, 2006 | 06:59 PM
Levi2000GT's Avatar
Levi2000GT
Default Leaking Head Gasket? :[[[[
My milage car, a 1994 Ford Explorer, (milage because I don't want miles on the stang! NOT because of it's miles per gallon) has been running really hot the past few days, and occassionally theh eater wouldn't work, just occassionally though, so I figured it had was something wrong with the coolant, so I went to get the oil changed and get the full service at express autolube, they said they think that my driver's side head gasket may be leaking coolant.
Is there a relatively inexpensive way to fix this that won't cost me a small fortune?
Old Mar 28, 2006 | 08:51 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Leaking Head Gasket? :[[[[
You could try some stop leak but I doubt it will work. Bite the bullet and fix it right if you are plannin' on keepin' it.
Old Mar 29, 2006 | 10:34 AM
Chopper's Avatar
Chopper
There's no way to fix a head gasket leak short of removing and replacing the head.
Stop leak is there just to get you home or to a shop.Never,never try to use stop leak as a permanent fix.
Given the cost of replacement heads it's best to keep an eye on fluid levels yourself and quit using oil change shops.There are innumerable threads on here about "jiffy lube" overfilling this and underfilling that.I have a relative that was one of the oil change shop's best employees and I wouldn't depend on him to so much as check the oil level let alone change it.
Old Mar 29, 2006 | 11:26 AM
angcobra's Avatar
angcobra
I would do a little more checking before I just assumed it was a head gasket leak. I maybe something like a heater hose.
Use a cooling system pressure tester to identify the leak for sure.
Old Mar 29, 2006 | 02:20 PM
Levi2000GT's Avatar
Levi2000GT
Yeah, was going to have it pressure tested later today, can anyone throw me a ballpark price of a replacement part?
Old Mar 29, 2006 | 07:37 PM
kartracer55's Avatar
kartracer55
A new head gasket wont be all that much. Labor will make you **** your pants
Old Mar 29, 2006 | 11:21 PM
tylerdru's Avatar
tylerdru
My dads 01 explorer had a cracked block. we paid like 5500 for labor and 2000 for the engine i think. It might have been 5500 for everthing.
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
69Volunteer
Sep 30, 2015 10:39 AM
wraith777
Sep 28, 2015 10:49 AM
Sep 27, 2015 03:16 PM
