5.0 Hp comparisons/questions
Old Mar 28, 2006 | 11:43 PM
speakerman86's Avatar
speakerman86
Default 5.0 Hp comparisons/questions
I've been doing some research on different 5.0 engines for a swap I'm working on and have come accross something that baffles me. The "88 through '92 mustangs had 225Hp with the 302 engine. The "88 through '90 Lincoln Towncar, and F250 had seemingly the same 5.0L engine rated at 150 Hp. All three vehicles had Ford's 302 engine. Not to mention the F250 had dual throttle bodies to allow for better air intake. What's the difference? Can I tweek a Lincoln computer to get the same Hp out of the towncar engine as the mustang? Small performance upgrades?
Old Mar 29, 2006 | 12:54 AM
speakerman86
Default RE: 5.0 Hp comparisons/questions
can anyone tell me what ford did to boost the hp?
Old Mar 29, 2006 | 04:01 AM
Liquid_02's Avatar
Liquid_02
Heads, Cam, Distributor, Intake and Injector wiring is all that's different.
Old Mar 29, 2006 | 01:49 PM
TBird232ci's Avatar
TBird232ci
Essentially, the 150hp engines are different engines in a way. They had different pistons, heads, cam, upper intake, throttle bodies, injectors, EEC's, exhaust manifolds...everything
The things they shared is the block, crank, rods, lower intake, fuel rails (depending on car), and just a handful of other things.
Old Mar 30, 2006 | 12:29 AM
waxyourboard's Avatar
waxyourboard
They can be classified as "HO" and non HO. Mercury grand marquis also had the same engines (non HO) and probably more.
P.S. Those grand marquis are such slow POS
Old Mar 30, 2006 | 01:56 PM
motormike's Avatar
motormike
The Ford Crown Victoria (2000) has 200 hp and the Mustang GT (2000) has 260!!! cams, heads, throttle, exhaust...ect.
they both have a 4.6
Old Mar 30, 2006 | 02:09 PM
speakerman86
you guys think that the 4.6 is a better engine? I've heard alluminum warps in major temp changes.....
Old Mar 30, 2006 | 02:35 PM
motormike's Avatar
motormike
ive never heard of warping...you can't beat 260 ponies out of a 4.6 though
some simple bolt ons and 300hp can easily be attainable
more room to work
newer engine, less problems
Old Mar 30, 2006 | 02:49 PM
speakerman86
Thanks all!! I've got another unrelated question: My project car has a rearend in it with 3:73 gear ratio. It was set up to the original 2.3L. Will it handle v8 power?
Old Mar 30, 2006 | 02:56 PM
motormike's Avatar
motormike
just for insurance, id get a master bearing kit and convert to 8.8 rear...just in my opinion
