Spring Install Labor
RE: Spring Install Labor
Figure at least $200, yes, average tire shops should be able to do it. Go ask around for quotes, they'll be able to tell you in a second about how much it will cost for them. Figure about a $45 average shop rate, and according to their book, it will take them 4 and a half hours to do.
I suggest doing it yourself, even if you bought the real spring compressors, you'd still be up on money, but autozone might rent them or something.
I did mine myself and so have many other. I bought the spring compressor for something like $30 or $40. Not too bad of a job if you have a little knowledge. If you want to buy my compressor let me know as I will probably not be using it anymore.
The shops around me refused to do it saying that it is illegal to change the geometry of suspension on my car bla bla bla
finally I got it done by a ford tech after hours for $200 ( springs,shocks,struts and cc plates)
Funny this topic comes up...
I have a time set up for tomorrow to get my lowering springs put on.. They gave me an estimate of $400 + $45 for a 4 wheel alignment..
Sounds like I'm getting ripped off but I really don't know much about cars or how to do it my self..
If I were to go get a Haynes manual book that I'd be able to do it my self? Also, is anyone able to give me a basic break down of how it would be done? If I were to attempt to do it my self, where would I get a spring compressor?
Thanks
Thanks
I'm in the process of lowering my brother's 1991 Integra with springs and shocks. I can tell you from experience that if the suspension and the bolts look rusted, it will be a headache taking them off or worse breaking bolts.
If the car's suspension was recently tappered with by a shop (bolts were tightened with a impact gun) it will be hard to take them out by hand.
But if your suspension looks clean and hardly any rust, do it yourself it isnt' that diffcult, really. Remember to grease up the bolts when you put them back in!
ORIGINAL: Mt Twigbert
Thanks
Thanks
That and the rear alignment on the car is not adjustable because it's a live axle setup. Then can tell you if it's in spec or not but they can't really do anything about it.
Do one side at a time and you can easily do it yourself. Impact gun is the easiest way to pop that nut off the strut without having to pull the whole bearing plate assembly.
ORIGINAL: projectstanger
