engine swaps
Old Apr 2, 2006 | 10:42 PM
9646gt's Avatar
9646gt
Default engine swaps
I have a general question about engine swaps: If it is obvious the motor will fit under the hood of the car, are the motor mounts the only thing you have to change to make it fit? (assuming that there is a trans attactched too)(example: putting a ford motor into an old camaro or something). Also, do they make special motor mounts for swapping, for example, a 4.6 into a 5.0? It might be a basic question, but i was just wondering, thanks.
Old Apr 2, 2006 | 10:45 PM
ShadowDrake's Avatar
ShadowDrake
Default RE: engine swaps
ORIGINAL: 9646gt
Yeah, anything is possible, really... you could make one hell of a bastard child vehicle.
The biggest issues to watch for are clearance from the firewall to the radiator, clearance across the engine bay, and depending on what transmission you get, clearance through the transmission tunnel.
A 4.6 should fit in a 5.0's bay... I think the 5.0 is a little wider... if it's not, even, it can be shoehorned in
Old Apr 2, 2006 | 11:12 PM
alexr's Avatar
alexr
ORIGINAL: ShadowDrake
ORIGINAL: 9646gt
it does. ive seen an 03 cobra motor in a notch.
Old Apr 2, 2006 | 11:16 PM
Twister's Avatar
Twister
you have it backwards, the 4.6 is wider, by a mile. You will need a different K Member for it to fit
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
