Problem starting car at times.
Old Mar 10, 2004 | 01:33 PM
HAUS's Avatar
HAUS
Default RE: Problem starting car at times.
well every once in a while the engine light comes on and then goes right off.
Old Mar 10, 2004 | 01:46 PM
pichinco's Avatar
pichinco
I don't have the pinout, but you can get the diagnostic code to find out why the engine light came on. It's based on a sequence of flashes, but it may help you pinpoint your problem.
Basically you stick a wire in the OBD connector, turn the key on and count the flashes of the engine light. There is a list as to what the codes mean. A Haynes manual would do wonder for you at this point. $15 at the parts store. Tells you how and what they mean. Also some good troubleshooting tips.
Old Mar 10, 2004 | 01:57 PM
HAUS's Avatar
HAUS
well i disconected the maf and started it up and it hesitated for a second and the reved at 2000 rpm for a few of seconds and then i went for a ride. it might be just my imagination but it seemed to have better acceleration then before and i did notice the engine light stay on this time. i know what you mean when you said squirrlly. why would it hurt my pride if anyone found out i disconected the maf.
Old Mar 10, 2004 | 02:59 PM
pichinco's Avatar
pichinco
hehe No, hurt your pride because you'd look like you couldn't drive a stick!!
You definitely need to get the codes and find out what's up. Bad gas mileage, engine light, hard starts, etc. OBD should tell you something. The last of which will be MAF failure....after all you diconnected it. <grin>
Old Mar 11, 2004 | 05:19 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
You definately should get the codes pulled.A buddy has a SNAP-ON diagnostics and it is by far the best out ive seen but not exactly cheap.Take it to any reputable shop or dealer and have them run the codes and then go home and fix it.
Old Mar 11, 2004 | 03:50 PM
HAUS's Avatar
HAUS
thanks for all your help guys. yeah ill defernitly get the codes checked and see whats wrong with tyhe car and ill let you all know
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
