battery acid
Old Apr 11, 2006 | 08:04 PM
alfromcal846's Avatar
alfromcal846
Default battery acid
hey everyone, today just as i about to go to school my car wouldnt start. so i look at my battery's positve terminal and its full of acid. i removed it and boom it goes fine. is there any other way to keep this stuff off because i dont want to be left somewhere and this crap happens again.
Old Apr 11, 2006 | 08:11 PM
randy78045's Avatar
randy78045
Default RE: battery acid
A good battery post cleaner should do the trick...
Old Apr 12, 2006 | 02:19 AM
karmstrong_2's Avatar
karmstrong_2
Rub some Vaseline on there...works like a charm from what I've heard
Old Apr 12, 2006 | 02:31 AM
kartracer55's Avatar
kartracer55
Thats not acid thats corrosion on the terminals. To get this off get a wire brush and some battery terminal cleaner/protector. CRC makes it and I believe there version is in a red can, but most companies make it. Easy to find at an autoparts store. Get these things cleaned up then get some of those felt terminal protector pads... there is a green and a red and they look like felt donuts that you slip over the terminal between the connector and for somereason they work like magic. Problem solved. Once you get them clean pull the wires off every few months and hit them with the spray.
Jim
Old Apr 12, 2006 | 09:29 AM
corvetteguy's Avatar
corvetteguy
I guess you are talking about the white
fuzz that apperars at the terminals.
Use water with baking soda to flood
the terminals to neutralize the acid.
Go to Napa and get a set of impregnated
felt battery washers and a $4 terminal
brush. Clean the terminal with the brush
and the cable ends and install the felt
washers, then the cables. Keep them
real tight.
It should last for years.
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
logan409
Sep 26, 2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Art161
Sep 9, 2015 10:33 AM
