Cobra R rims
Old Mar 14, 2004 | 03:18 PM
ToplessMustang's Avatar
ToplessMustang
Default Cobra R rims
Quick question: Do they make 18" Cobra R rims 8.5" wide? The normal size is 18x9.5. I see references to 18x9, but I'm wondering if they make 8.5" ones.
Reason: Just put 18x9.5's all around on my car with 275's all around. The edge of the rims are even with the tires so there's no protection from close encounters. Also, the front wheels stick out from the fender slightly - don't like this. And, the back ones are in a good distance. I would like to make take the front ones to 265 or 255 with a 8.5" rim - will pull them in and give rims protection. Then put 285 or 295 on the back with the existing 9.5 rims. Then nothing will be sticking out of fender, all rims should have a little tire protection, and the tires will come to the edge of the fender(but not further than).
So I don't think 8.5s will do it - I think I would need 18"x8" cobra r's. Do they make them?
Any help greatly appreciated!
Old Mar 14, 2004 | 03:20 PM
ToplessMustang
Default RE: Cobra R rims
ORIGINAL: ToplessMustang
Oops, sorry, should be NEED 8.5s, and I don't think 9" ones would do it! Looking for 18"x8.5" Cobra R's - exist or not?
Old Mar 14, 2004 | 03:31 PM
98LS1's Avatar
98LS1
I have no answer to your ?, but there is an edit button on the top right of each post. Just a lil FYI for future mistakes.
Old Mar 14, 2004 | 03:54 PM
SpeedRicer's Avatar
SpeedRicer
i haven't been able to find any 18x8.5's, have you thought about going with 17's in the front?
Old Mar 14, 2004 | 04:04 PM
ToplessMustang
Hmm... no I had not thought of that. That means that with a 17" rim if I wanted ~same low profile look = smaller over all diameter OR to keep the same size diameter I would have to have a larger profile tire - so the profile would not look the same as the back.
I would guess the first option: ~same profile look with smaller overall diameter for the front would be the only way to go. Your thoughts?
Old Mar 14, 2004 | 04:07 PM
ToplessMustang
95LT1: Thanks for the edit button hint - never noticed that before!
Old Mar 14, 2004 | 04:21 PM
HRnB's Avatar
HRnB
Administrator
This may be a stupid thought, but if you have built in rear offset wheels and they're sticking out in the front you may have the rears on the front. Just a thought. Are they Ford Cobra R's or copies?
Old Mar 14, 2004 | 08:41 PM
ToplessMustang
Not familiar with offsets and front vs rear rims. I'm sure they're not copies - bought them from Performance Plus, Madison. They installed them also so I'm sure they are on correctly.
Old Mar 15, 2004 | 10:08 PM
HRnB's Avatar
HRnB
Administrator
You might want to double check. Because the 9.5 x 18 Cobra R's I was going to buy had the rear off set built in. It's there to push the rear wheel out so it looks better in the fender well. Maybe the place you got the from did not know that about Cobra R wheels. I'm going with a 9.5x18 front and a 10.5x18 rear instead off the off set.
Nov 10, 2015 11:39 AM
whatsup62
Oct 16, 2015 03:07 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
Sparks_88
Sep 8, 2015 01:06 PM
