Shorter tires up front?
Old Apr 24, 2006 | 08:29 PM
checkuself1222's Avatar
checkuself1222
Default Shorter tires up front?
Hi guys,
I just ordered new tires and ordered 245/40/17's up front not realizing that they would be a good amount shorter then the 275/40/17's in the back, does anybody think there will be any problems with this setup?
Old Apr 24, 2006 | 09:45 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Default RE: Shorter tires up front?
they are less than 1" shorter than stock
i got a 24.7 to a 25.6 for stock height
dont worry about it,,
wont do much at all, if anything, it'll give it a raked stance
Old Apr 24, 2006 | 09:49 PM
checkuself1222
Ok thanks, just wanted to make sure.
Old Apr 24, 2006 | 11:50 PM
GreyStang's Avatar
GreyStang
Won't different diameter tires front & rear confuse the ABS & traction control sensors?
Old Apr 25, 2006 | 01:45 PM
72MachOne99GT
people get taller rear tires all the time,, that is why the dallas speedcal and tuners are able to calibrate for tire changes,,, so there shouldnt be any worry..
as for the TC,, i wouldnt think that changing the front tire height only would make any difference on the sensing of wheel spin or loss of traction
Old Apr 25, 2006 | 02:20 PM
GreyStang's Avatar
GreyStang
Well, doesn't the way TC determine if you have wheelspin by comparing front wheel RPM to rear wheel RPM? A very subtle difference, like 1", between axles probably wouldn't be enough to have it react. But I would think if someone stuck some radically huge tubbed slicks in rear & tiny bicycle wheels up front, TC would probably have a heart attack each time your drove, regardless of if traction was good or bad..(?)
And the deal with tuners adjusting for wheel size,, I think that is more to compensate so as to let your speedometer read correctly. Do tuners give you the choice to say "my front diameter is THIS & my rear diameter is THAT?" I'm not sure,, never used a tuner before.
Old Apr 25, 2006 | 02:32 PM
72MachOne99GT
im not sure about your first paragraph, im not 100% on how TC works in sensing and what not
as for the quoted text, i assume it asks your the size of the rear tires, which the diameter is computed to determine the corrections to make for the speedometer
i know that the front diameter doesnt have anything to do with the speedometer, so i cant see why it would affect the rear at all
does that seem logical? or do you know something i dont?
Old Apr 25, 2006 | 04:15 PM
NeFiLiM's Avatar
NeFiLiM
when i run my 26" slicks out back and keep my regualr tires up front and drive it itl turn Tc off by itself but i think hell be fine with what he has it wont set it off
Old Apr 25, 2006 | 09:55 PM
MustangChris04's Avatar
MustangChris04
what happens when you have tc on with big tires in the back and small up front?
Old Apr 25, 2006 | 09:57 PM
72MachOne99GT
i dont think it would be anything....
wheel spin is wheel spin, therefore TC kicks in...
i may be wrong, but i cant see any reasons the computer would be affected
