timing ?
Old Apr 25, 2006 | 02:47 PM
mark54's Avatar
mark54
Default timing ?
does any body know where the distributor rotor should be facing at tdc ,on a 74 351w. i'm trying to start it for the first time, i'm getting some fire from the headers but only on occasion , i'm assuming this is a timing problem?
Old Apr 25, 2006 | 03:03 PM
FastLane's Avatar
FastLane
Default RE: timing ?
There is no set spot for it to face.
you need to bring the #1 cylinder to TDC on the compresion stroke and check to see that the rotor is pointing at the #1 terminal. if not then rotate the dizy so the rotor does then try again. once it starts you will need to time is with a light.
Old Apr 25, 2006 | 03:10 PM
mark54's Avatar
mark54
thats what i thought.i'm also having some battery issues it may just not be cranking enough to fire
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
