best liquid wrench
Old Mar 23, 2004 | 04:40 PM
71455olds's Avatar
71455olds
Default best liquid wrench
I am installing headers on my 5.0 need to know of any recomendations on penitrating oil to help break the header bolts (i bought PB but never heard of it) (have 190k on them but cracked the stock header)
I want to soak the bolts for 2-3 days then thow a torch on them when I try & take them out. any other idea's will be appreciated.
Old Mar 23, 2004 | 04:50 PM
WNDSOR's Avatar
WNDSOR
Default RE: best liquid wrench
i like the PB myself, i'm sure about heating the headers though, try to combine two wrenchs to get some leverage first
Old Mar 23, 2004 | 07:05 PM
roundman's Avatar
roundman
I always had good luck with the "Liquid Wrench" brand of penetrating oil myself. I didn't have that much trouble getting the bolts out of mine and I did it after owning the car for 6 years. do like you said, soak them good about twice a day for a day and then use a pull bar and 12 point socket on them and ease them loose. you don't want to wring one off as that will be a pain in the *** to deal with. be easy with the heat, too easy to damage something else while you using it.
Old Mar 23, 2004 | 07:13 PM
WNDSOR's Avatar
WNDSOR
yeah, i've never really had much trouble with mine neither, but depends on header if you can use a socket and rachet. i just use a open end wrench and put a little weight behind it.
Old Mar 23, 2004 | 07:16 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Ive never had any problems on mine.But i always use a heating torch to get them hot them back them out slowly.
I suggest you get some high temp anti seize for the new bolts so that this isnt a problem.I use it on my spark plugs,header bolts,intake.Anywhere i may need to get them off easily in the future.Just remember a little goes a long ways.
Old Mar 24, 2004 | 01:47 AM
MelloYello's Avatar
MelloYello
Liquid Nitrogen Or a an engine hoast and a BFH
Never had problems with taking mine off.....
Old Mar 24, 2004 | 02:14 AM
VertStangGT86's Avatar
VertStangGT86
There's a pentrating lube made by toyota that's amazing. It's all my buddy uses, I can't remember what the specific name is though.
Old Mar 24, 2004 | 08:16 AM
Brian18034's Avatar
Brian18034
The shop I work for uses PB Blast and I have heard no complaints. Soak it down the day before and let it sit 24 hours. I have seen some amazing results.
Old Mar 24, 2004 | 10:17 AM
jj87gt's Avatar
jj87gt
No one uses W-D 40, anymore?
Old Mar 24, 2004 | 01:29 PM
roundman's Avatar
roundman
WD 40 ain't really a penetrating oil, it's more of an all purpose lubricant but if it works for you, go for it!
