PCM and DTC's
Old Apr 30, 2006 | 02:54 AM
Parsel Tongue's Avatar
Parsel Tongue
Default PCM and DTC's
1998 SVT Cobra Convertible 4.6L Modular...
Having trouble with my PATS I think - The car will not start all of the sudden. All of the lights and accessories work as normal, but the starter is not turning. It's almost like the clutch switch is malfunctioning, the pcm is fried, PATS is screwed up, or the key chip is bad?
Can I get the codes w/o a scanner? I know some other vehicles you can turn the ignition on/off and the MIL will flash the codes.
Thanks- oh, and this is my second post! (not having much luck with the search yet)
Old Apr 30, 2006 | 04:20 AM
ShadowDrake's Avatar
ShadowDrake
Default RE: PCM and DTC's
ORIGINAL: Parsel Tongue
If the PATS is acting up, it'll crank but won't start. If your starter isn't cranking it, you could have a bad starter. That's where you should start.
You'll need a scanner to get codes out... the 99+ stangs have a digital odometer and can get codes out through that, but you don't so you're out of luck... you can get codes scanned for free at most AutoZones.
Old Apr 30, 2006 | 02:44 PM
Parsel Tongue
Thanks ShadowDrake!
If it was the starter, would I still hear at least a click or something?
I'll search for a good scanner. I hate to get it towed to the dealer and they charge me 100's of dollars for something I can do.
Weather finnally broke here in N. Idaho and I can't drive it with the top dropped![:@]
Old Apr 30, 2006 | 02:52 PM
Parsel Tongue
Ok, just went into the garage and fired it up - started right up this morning like nothing was ever wrong. I'm relieved, but concerned about where I'll be for the next foul up.
I may drive up to AutoZone now
Old Apr 30, 2006 | 04:01 PM
Parsel Tongue
Another update:
Just got back - no codes and the engine is starting 5 times faster than ever!
Oh well, I'll keep my cell on me
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
bryan616fl
Jan 25, 2019 09:07 PM
StangMuscle
Aug 12, 2015 07:27 AM
HIS S-197
Aug 10, 2015 05:47 PM
