URGENT PROBLEM
Old May 2, 2006 | 10:30 AM
1998GT's Avatar
1998GT
Default URGENT PROBLEM
i have a 1998 gt convertable and i just ccame back from a week away.....and i tried to start the car but all i get is one click. the battery is still charged..........wat can i do or what could be the cause of the problem????
Old May 2, 2006 | 10:53 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: URGENT PROBLEM
Shorted connection or a bad starter/solenoid
Old May 2, 2006 | 10:55 AM
turbostang21's Avatar
turbostang21
starter/alternator/battery....sounds like a starter. try to jump start the car...if it works then you ruled out the starter.
Old May 2, 2006 | 10:58 AM
monkeydude3's Avatar
monkeydude3
how did you test your battery?
Old May 2, 2006 | 11:01 AM
1998GT's Avatar
1998GT
when i turned the car on the cd player was working fine and the guage was at around 7
1998GT's Avatar
1998GT
i did jump start the car and nothing happened the cd player worked thee whole time and i still got the click
Old May 2, 2006 | 11:21 AM
monkeydude3
ur gauge was at 7 volts??!?
Old May 2, 2006 | 11:28 AM
monkeydude3
if you said your gauge was at 7 and tha tmeans it's down to 7 volts. that may be too low for a jump in some cases. check each cell in the battery. It may be dead [&:]
Old May 2, 2006 | 03:08 PM
mattkoly's Avatar
mattkoly
New battery, take it in to auto parts store and they can test it and tell you for sure...
Old May 2, 2006 | 03:55 PM
Sean97's Avatar
Sean97
I had the same problem a while back. Try hooking your battery to someone elses for like 20-30 minutes. It worked for me. I ended up having to buy a new battery though.
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
