transbrake? questions
Old May 11, 2006 | 10:18 PM
straitwangin's Avatar
straitwangin
Default transbrake? questions
Hi i was wondering what a transbrake was? I have never raced automatic vehicles and i know many prostreet guys are running turboglides and other various automatic transmissions. How does it work? and what are the main bennfits when using a trans brake?
Old May 11, 2006 | 10:26 PM
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: transbrake? questions
ORIGINAL: straitwangin
First off, automatics are the best hands down, secondly a transbrake is just what it sounds like, you can stage hit the transbrake and bring the converter to full stall without worrying about creeping through the stage beams. When you release the transbrake it hits instantly.
Old May 12, 2006 | 12:40 AM
straitwangin
yeah i know auto domoniate the strip world, but i still love my 5 speed. so it basically allows you to reve the motor to a cetrain degree much like when im slippin the clutch and then launch the car. then it enguages and takes off?
how does this not blow the converter when it attaches at 3k+ rpm?
Old May 12, 2006 | 12:22 PM
turt's Avatar
turt
trans brake is more for auto trans. manual trans enjoy line lock. this locks front brakes. as for the converter question, dont worry about it. you dont have one on manual shift trans. the clutch takes its job. drag strip launches take alot of trial and error. there is ALOT of tricks and devices used. you will like the line lock.
Old May 12, 2006 | 12:25 PM
93BlackNotch's Avatar
93BlackNotch
A trans brake is like neutral dropping the car, except it dosn't hurt the trans... It puts the trans between 1st and reverse by pushing a button, usually you rev (with a 2 step) anywhere between 2500-5000 rpms, and when you release the button the trans engages HARD... It's only good if you have slicks on the car or you will just be wasting your time.... It's mainly used on high HP applications
Old May 12, 2006 | 05:03 PM
straitwangin
i was just wondering because ive seen them on many auto matic drag vehciles, and i always wondered how it worked
thanks guys.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
