Is this going to be a problem?
Old May 14, 2006 | 05:20 PM
OpalFrost's Avatar
OpalFrost
Default Is this going to be a problem?
After driving for 10 minutes or so in my 95 v6, the temperature guage goes up to the A in "NORMAL" and stays there. I never really drive the thing for more than 30 minutes straight and it isn't even very warm outside. Is this a sign that I'm going to have problems when the day comes that I have to drive for 2 hours in 90 degree weather or am I just being paranoid?
Old May 14, 2006 | 05:41 PM
ShadowDrake's Avatar
ShadowDrake
Default RE: Is this going to be a problem?
That's not normal, way too high... You could have a sticking thermostat, you may want to check that out (even replace it, a new thermostat is dirt cheap).
Old May 14, 2006 | 05:51 PM
randy78045's Avatar
randy78045
an check your coolant level...
Old May 15, 2006 | 03:49 AM
SXGT's Avatar
SXGT
See if your fan is running wil the engine is on.
Old May 15, 2006 | 03:22 PM
cepowers18's Avatar
cepowers18
I had a 94 v6 before I bought my GT and I had the same problems with the temperature. I changed the thermostat, changed and flushed out the radiator system, always checked coolant levels - nothing worked. My head gaskets were blown. Matter of fact, those things blew on two different occasions.
I'm not saying that's what is wrong with your v6, but it's an expensive operation if so.
Old May 15, 2006 | 08:14 PM
OpalFrost's Avatar
OpalFrost
ShadowDrake: I'm pretty sure there's nothing wrong with the thermostat
randy78045: The coolant level was actually very low, but I filled it up and the car's still running hot
SXGT: Checked; it's fine
cepowers18: The head gaskets were a big problem with these cars, weren't they? I bet that's the problem
Old May 17, 2006 | 03:25 PM
OpalFrost's Avatar
OpalFrost
Anyone else have any idea?
I also noticed that my oil pressue is a little high, too. It's towards the end of the M, almost between the M and A
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
