oil drip....??
Old May 18, 2006 | 12:09 PM
ffstang's Avatar
ffstang
Default oil drip....??
a couple of months ago, i just bot a 94 mustang gt conv. ( low 40 k miles) with vortech supercharger, had the car checked by a couple of mechanics including the shop that installed the supercharger and and the car checked out in good condition. However, i've been noticing "a little oil drip" under the engine sometimes daily, sometimes none for a couple of days and then again a little oil drip after a few days...should i be alarmed or is this normal because of the supercharger(since the car is running under extreme high pressure)? I understand that i need to monitor very carefully my oil levels and use "only synthetic oil" if i'm due for an oil change.
i would appreciate any past experiences or any insights on this . thanks!
firefighter in chicago
Old May 18, 2006 | 12:38 PM
11steven22's Avatar
11steven22
Default RE: oil drip....??
i would check were the oil pan was tapped for the oil return line for the supercharger.
Old May 21, 2006 | 06:47 PM
rcobra's Avatar
rcobra
Also check just behind the oil pan, between the pan and the transmission, often a 5.0 will weep oil in this area. A mechanic a talked to once says this is common with 5.0 engines. If it is not a lot of oil, usually cleaning off the excess with each oil change helps keep the floor clean. Check oil level to insure the level is not going down. If a lot of oil is in this area, may be a rear main bearing leak.
Old May 21, 2006 | 07:33 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Make sure the pcv system is working correctly!
wraith777
Sep 28, 2015 10:49 AM
Shadow7874
Sep 24, 2015 09:06 PM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
kevsgt
Sep 9, 2015 06:20 AM
