HELP LOST OIL PRESSURE
Old May 25, 2006 | 02:28 AM
KillSwitchNY's Avatar
KillSwitchNY
Default HELP LOST OIL PRESSURE
my car has been fine for a while and all of a sudden while i was driving my mechanical aftermarket oil press guage went from my normal 50 psi all the way to 0. i drove the car home when that happened which took 10 mins at 2k rpm. nothing smelled burning or smoking. i shut the car off at home and turned it back on and there was a valve tick. took it to the shop and they said right off the bat it was my oil pump.
My motor has less than 10k miles on it so i dont see why the pump would be bad just like that. but the shope called back and said they did the pump but that wasnt the problem and they have yet to figure out whats wrong.
please help with what this could be. and if a shop diagnoses a problem then fixes what they think it is and that isnt actually the problem, should i legally not have to pay.
Old May 25, 2006 | 02:36 AM
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: HELP LOST OIL PRESSURE
if you had 0 oil pressure for 10 minutes straight I guarantee the bearing are or will be wiped very shortly down the road.
Old May 25, 2006 | 02:41 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: KillSwitchNY
Get a test unit like shops have and test the pressure. You may have a faulty sender, or gauge
Old May 25, 2006 | 02:49 AM
KillSwitchNY
ORIGINAL: 03YellowPony
if the guage or sending unit were bad that would be a huge relief but i already thought of that and being that the top end is tapping like a bitch. i doubt that what happened.
Old May 25, 2006 | 02:56 AM
KillSwitchNY
ORIGINAL: myshifter
i really hope not. ive had 2 4.6 motors blow on me. well those were supercharged and detonated cuz of my peice of **** aod tranny would not shift properly and detonated the bastard. but still i fell into a downward spiral both times cuz this **** aint cheap.
there was no knocking on the bottom from a rod or bearing or anything, like i said i know exactly what that sounds like. but you think even tho theres no sign of damage now... after i get my oil back to normal it could blow?
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
marc954
Sep 29, 2015 03:05 PM
wraith777
Sep 28, 2015 10:49 AM
marc954
Sep 25, 2015 06:48 AM
