tps
Old May 27, 2006 | 06:14 PM
2002blkgt's Avatar
2002blkgt
Default tps
hey guys, i have read the instructions from accufab on setting the throttle possition sensor and still can not get the correct voltage(.98 to 1v).
any experience in setting it.
thanks
Old May 28, 2006 | 02:37 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: tps
What exactly are you having trouble with? What voltage are you getting?
Old May 28, 2006 | 05:19 AM
2002blkgt's Avatar
2002blkgt
Default RE: tps
i am getting an irratic voltage, jumping back and forth. i have a check engine light with the code p0122 which is throttle position sensor output voltage. any change of plenum requires to remove throttle position sensor and reinstall. i figured this would be a common problem but no one seems to know. my stang idles fine but from 800 to 1100 or so it is sluggish on the throttle sometimes wants to jump. any help would be greatly appreciated.
ShaneB26154
35
Mar 4, 2021 04:05 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
bmorrisj
May 27, 2004 06:18 PM
