T/B Ineffective w/o Porting?
Old Jun 3, 2006 | 03:11 PM
Rook6's Avatar
Rook6
Default T/B Ineffective w/o Porting?
I don't remember what thread this was said in or by whom, but someone said that larger throttle bodies would yield no benefits without a ported intake. Could anyone elaborate on this? Is this true, or only to an extent?
Old Jun 3, 2006 | 03:45 PM
03YellowPony's Avatar
03YellowPony
Default RE: T/B Ineffective w/o Porting?
ORIGINAL: Rook6
It's true..on a 6er anyway. Not sure about the 8's. If you put on a bigger t/b w/o porting the intake too, you're creating a "step" effect. Which creates turbulance, which can rob you of power.
Old Jun 3, 2006 | 04:10 PM
Rook6's Avatar
Rook6
Thanks again
Ya know, it's getting to the point where I might as well just start an "Ask 03YellowPony" thread. lol
Old Jun 3, 2006 | 05:01 PM
alexr's Avatar
alexr
think of it this way:
if you have a steel tube that is 3" in diameter, just putting a fitting on it thats 1" larger in diameter (4" total)wont do anything because the rest of the pipe is still only 3".
but say you get a pipe that is 4" (same concept as porting in this case), but yet you still only have the original 3" fitting (stock throttle body), then youre restricting air flow because of a smaller fitting on a larger tube.
thats when buying a larger TB comes in play. usually you buy a larger TB when the intake is big enough to accomodate the larger TB, and when the stock one is causing restrictions.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
mrappe
Sep 26, 2015 10:16 AM
