Leaded race gas?
Old Jun 26, 2006 | 12:06 PM
SleepingGT's Avatar
SleepingGT
Default Leaded race gas?
as long as i don't have converters i can use leaded race gas without hurting anything right?
Old Jun 26, 2006 | 12:11 PM
P Zero's Avatar
P Zero
Default RE: Leaded race gas?
How about a car desciption. The lead might deposit on injectors. If its carbed, you wont have any problems whatsoever.
-P.
Old Jun 26, 2006 | 12:30 PM
SleepingGT's Avatar
SleepingGT
2000 4.6 2v ? I need to use a higher octane for the giggle juice
Old Jun 28, 2006 | 12:28 AM
gt96stang's Avatar
gt96stang
Run premium... It only requires 93 octane..
Old Jun 29, 2006 | 06:42 PM
4Stangs's Avatar
4Stangs
If the motor is stock, you should be able to tune for the nitrous and use premium 92 up as long as you use a wet system. If you want an agressive tune (more timing) a 50/50 mix will be ok to use for trips to the track. Whatever you do, get an accurate air/fuel reading and make sure the car isn't too lean for the spray.
Old Jun 29, 2006 | 06:51 PM
4Stangs's Avatar
4Stangs
How much spray? 75 HP should be ok as long as you get that timing and air/fuel mix right with 93 pump gas.
ctgreddy
Sep 20, 2015 08:35 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
algregory
Sep 11, 2015 11:44 AM
Sep 9, 2015 10:30 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
